Carplay vs A/C
MachErena
Todd
Hershey, PA
2022 Ford Mach-E select
Safety manager
When the car is warm and the A/C is on CarPlay impacts the flow of air from A/C. If I receive/make a phone call the A/C goes down and does not blow as hard. So, I have to sit and sweat while on the phone or it takes much longer to cool the cabin down. Is this a setting or normal behavior due to pulling juice for two competing accessories?
2022 Select w/ AWD
Logal727
C
2022 Select w/ AWD
This is part of the CarPlay protocol for every car that is equipped with it, not just Mach-E. I’ve never had an issue with it though and I’m in Florida. It turns down the fans so it makes it easier for the microphone to pick you up.
Yup, it’s designed this way.
You can manually increase the fan speed, at the risk of a bad sounding phone call.
Pretty easy workaround though.
Gullwingdmc
Chip
Boston, MA
It’s not CarPlay, it’s the car. It does it with regular old Bluetooth calls and the cars voice assistant too. Any time the car knows the mic is in use it drops the fan to reduce noise, pretty ingenious actually.
ripperAZ
Ripper
AZ DESERT
You should be happy they had the chips to install to make it work. it makes hands free calling possible.
Jes sayin. Hit the fan button and talk louder like my grandpa does.
TGIF
IA
This brings up an ancillary issue of knowing when something is a bug or a feature. I still haven’t figured out when the puddle lights are supposed to come on. I’ve seen them a couple times but have no idea what I did to make them appear.
JohnnyForensic
VA, US
Digital Forensics
It’s a standard feature now across most cars with a built-in microphone for phone calls. When you activate the voice assistant (Ford or Siri), the car slows down the fans to make you more intelligible to the microphone. My Acura RDX did it, my Honda Odyssey does it, and so does the MME. This is a regular thing now.
JohnFoxeSheets
San Francisco
johnfoxesheets.com
Ford Mustang Mach-E Carplay vs A/C Screen Shot 2022-07-24 at 4.17.34 PM
(The Owner's Manual has all kinds of interesting information ? )
MachErena
MachErena
Todd
Hershey, PA
Safety manager
Thanks so much for the insight. I definitely was not complaining. Just curious to know why it slows down. The reason makes perfect sense. I appreciate the finer details the engineers thought of!
STL-Mach-E
Steven
St Louis
2021 Escape PHEV, 2023 MME GTPE
2022 Select w/ AWD
When it is 100 degrees, and your just beginng your drive,, I also find this annoying!
