CarScanner data graphs
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
I don't use AI. And if I did, how would it know the script issue with someone's code that it can't see?
I am using the CarScanner CSV script. https://github.com/babgvant/CarScannerCSV/blob/main/README.md
This script converts/cleans up Car Scanner CSV files. It is based on the work of Sam (phidauex) from the Mach-E Forums who was nice enough to share his parsing script with me.
Usage:
FormatCSV.py -i -o [-a -s ]
-a will return all columns in input CSV (the default is to remove columns that aren't relevant to looking at the charge curve) -s specify the sample rate that the data will be compressed to, the default is 30s
So I first start Python, and get the prompt, then, while in the subdirectory where the data file is (rawdata.csv), what do I do?
Don’t you have the py file? You can give it that and the command line that you’re calling it with. It will likely tell you the solution in a couple of minutes.
YeOldeTraveller
Clark
Ann Arbor, MI, USA
2024 MME Rally
I have been unable to reproduce the error with a test script on my system, but it is a work computer, and I have gone as far with that as I can justify.
A few more things to try:
python .\FormatCSV.py
python "FormatCSV.py"
python ".\FormatCSV.py"
Another possible solution would be Windows Subsystem for Linux, which is a virtual environment on the Windows machine running Linux with integrations to the Host system.
Same error on all of those.
I give up. Not that big a deal.
Thanks for your help.
