Charge % @100% but range @ 195
05reinvent
Steven
Newbury Park, CA
Mach E
Will Mach E contine to charge up to 250 miles (Range) even though % Charge indicator says 100%?
No. 100% is the max you will see.
Estimated range at 100% will vary based on several factors. Primarily usage and temperature. As usage and temperature changes, so will the estimated range.
You've posted a number of times about your range. You live in an area where the temps go down into the 30s at night. When temps drop, range drops.
You can never charge to more than 100%.
Just got my vehicle updated last week. At 90%, I was up to 209 miles. Yesterday 195. Today 202. All due to temperature.
05reinvent
Steven
Newbury Park, CA
Mach E
All forum responders
Thank you for all your replies. I do live in Southern California and even in winter, temps north of 40F. I have had this vehicle for 7 mos, and all during that time 250 max @ 100% charge was easily achieved in all conditions. Suddenly can't get range over 186 with % charge @ 100%. Thx for all the help, I just can't believe its weather related. Temp right now 52F.
Right now? What was it when you checked the range and posted it?
And 52 is by no means ideal.
My car said 209 the other day at 90%, then 195 yesterday. Now it says 202. It is 44 out.
jdmrc93
Allen Park, MI, USA
2024 Mustang Mach-E GT Performance
IT Network Engineer & Systems Architect
It also takes your driving habits into account, along with how you're heating your car, outside temp... etc etc etc etc.
My 90% max charge typically says about 180 on my First Edition. I'm a absolute lead foot, it's 25 degrees out (Fahrenheit), I run E-heat, heated seats and wheel. So I'm basically in the exact same ballpark as you. My 100% state of charge would render me about 198 miles.
Just a perk of EV ownership.
I disagree.
Every coach has always told me to “give it 110%”
Are you calling them liars?
05reinvent
Steven
Newbury Park, CA
Mach E
198 @ 100% sounds reasonable but 186 @ 100% in warm southern cal with no heat is not consistent. BTW master reset does nothing. Do you agree it ain't working right?
Thx
05reinvent
Steven
Newbury Park, CA
Mach E
It's working as expected
In the process of troubleshooting real or no real problem, I did something. I RESET EV DRIVING HISTORY. Voila, range jumped to 195 @ 94% charge. Maybe close to proper values.
KZ6e1e
LAX
P4X
You do realize that does nothing in real life. That's just an estimate based upon current temp and 0 driving history.
Your 100% is still 100%.
05reinvent
Steven
Newbury Park, CA
Mach E
Ok. Based on current temp (55F) + zero driving history, I would expect
More like 220 @ 95% charge. 7 mos driving now it seems like MachE has done a context seitch
