Charge Fault
Aferreira613
Andrew
Bancroft Ontario
2022 Mach E
So I’m suddenly unable to fast charge my mach e as it generates a charge fault message in the vehicle. Solid amber indicator light as opposed to flashing so the problem seems to be with the vehicle and not the charging station. Same issue with three different fast chargers. Any clue as to what the problem might be or is a trip to the dealership in order?
What type of chargers are you using, and have you used them before with the Mach-E?
Hard to say what the problem might be with that limited information. Could still be user error or a charger issue unless you tried a different brand of station as well.
Aferreira613
Andrew
Bancroft Ontario
2022 Mach E
We were using electrify Canada chargers and yes, I have used them severs times before.
AKgrampy
Fairbanks, Alaska
Did you try it on other fast charger networks other than Electrify Canada? Is L2 still charging correctly?
petertar
Pete
Harwich, MA
2021 Mustang Mach E GT
I'm experiencing this exact problem. The chargers i attempted to use are variants of the Chargepoint Express stations(64kw). Some run by Florida Power & Light(FPL Evolution) and a private Chargepoint unit. I have used all of these chargers before with no problem. L2 charging works. It is kind of sad to pull up to a bank of chargers with Hyundais, VWs and Rivians all actively charging and me jumping from charger to charger with repeated failures. I made the trip 3 weeks ago from Cape Cod to Naples, FL successfully charging all the way at Electrify America, EVgo, and FPL Evolution chargers. Now I can't seen to get a fast charger to work. Any ideas?
