Charge Port Door Won't Close - Part Fell out... Easy fix?
BostonPete
Pete
Boston, MA
2021 Premium ER / AWD Built 12/21
Hello -
First issue with my MME since getting it (other than some software glitches) We had rain then pretty much a flash freeze so my Charge Door was a little difficult to open when I got home from work but nothing crazy. Went I left for work it was a little difficult to close as well. I got to work and the door would not open. I ended up getting it to open but the little rubber part of the door looked a little messed up so I fixed it and went to close the door, as soon as I did I hear something falling out of the car and hits the ground.
It doesn't look like it is damaged, it just seems like it popped off / out somehow. Any chance I can put it back in place?
Ford Mustang Mach-E Charge Port Door Won't Close - Part Fell out... Easy fix? 1671909948758
WyldStallyn
Jody
New Hampshire
2021 Mach-E GTPE
Hello -
Ford Mustang Mach-E Charge Port Door Won't Close - Part Fell out... Easy fix? 1671912156850
Ford Mustang Mach-E Charge Port Door Won't Close - Part Fell out... Easy fix? 1671912311209
WyldStallyn
Jody
New Hampshire
2021 Mach-E GTPE
Almost 20 months with the car and I’ve never had this happen. Something is amiss.
It happens after a hard rain and then a freeze like we just had in the northeast yesterday. I had no problems from delivery in January until November but we didn’t have any of those events. This is my third time since November. Dealership is going to swap out the assembly with a new one to see if it makes a difference.
I’ve been using a deicing spray since the last time but it didn’t help.
BostonPete
BostonPete
Pete
Boston, MA
Plan on needing to pop it back in place "regularly". I have had to do mine twice in the last month.
Woah ok so it looks like a relatively easy fix? The images are a little cut off especially the second one... So it looks like that panel comes off? I just push down the 4 "Locks" and pop the panel off and I should be able to put the part back in place?
Taking a closer look at it how do you unlock the 4 clips holding it in. Do you just stick a screwdriver in the slots? I hope / assume this can be done from outside without taking the frunk apart?
Thank you so much, I was looking for a service / repair manual but couldn't find one cheap. yet.
WyldStallyn
Jody
New Hampshire
2021 Mach-E GTPE
You just need to release the clips shown in the first image. I just showed the second image cropped to show the socket. It is pretty easy as long as it isn’t still frozen.
Shayne
Northern Ontario Canada
2021 MME4x Prem
Me either but you need to treat it with kid gloves. It becomes a bit of a pain when out side and snowing. I have a sock that goes over the head of the charger and seals the connection pretty well. It is the snow and ice that collect in the bottom of the compartment that requires attention. I have got the hair drier out before. It would be better if it flipped up and made a roof. A lot could be done to make it more solid and practical. I would say it is a bit flimsy for something you are into more than ICE.
BostonPete
BostonPete
Pete
Boston, MA
Hi I am finally out of work and I took a look at it, how do I release the clips? I tried sticking a small smudge tool in and it doesn't seem like they move? I don't get it based on the photos?
Detailed directions would be greatly appreciated.
mmulk123
Massachusetts
2021 Mach-E Select
I'm having the same issue. Was anybody able to figure out how to release those 4 clips? Does this have to be accessed from the inside or can they be opened from the outside?
Rhmj1982
Roberto
Orlando
Mach-e GT 2023
good evening guys, anyone did manage to successfully unclip those 4 clips? Im trying tomfigure it out here but afraid to break something holding it.
johnnycombo
Pennsylvania
Mine never popped out, but when it doesn’t latch or unlatch the first time, I spray a little silicon lube into it.
Shootdapuc
Keith
Sayville, NY
Ford Mustan Mach E Premium AWD
did anyone ever solve for this? I have the same issue - would love to know if you were able to remove the latches to access inside?
Rhmj1982
Roberto
Orlando
Mach-e GT 2023
I ended up paying 1.5hs labor time to the dealer to replace the part :-S It's a top 20 min job but the dealers take advantage on us.
