Charge port weather kit
DeusEx
New York
2023.5 Mach-E Premium ER AWD
It works okay. You sneeze or look at the rubber cover wrong and it will pop out. I have it and am currently using it, but the fitment could be a lot better.
Or for $10 a universal cover. Simple sometimes is better.
Everytime someone posts one of these, we remind them that magnets won't stick to the fender.
WallyS56
Keith
Washington
2024 Mach E Premium, 1969 Mercury Cougar, 1971 Ford Ranchero, 1993, F150 XL 4x4
Teacher
Wytwolf
Canada
2024 Mach E Premium ER AWD
I agree. Though it is not perfect, if you lightly wedge something between the cover and the arm it helps the cover stay in place. I use 1/2 of an old wooden clothes pin.
DeusEx
New York
So yours pop off from the left? Mine typically pops off from the right and this is what I came out to this morning.
Ford Mustang Mach-E Charge port weather kit Screenshot_20260201-134702
WallyS56
Keith
Washington
Teacher
Hmmm. Mine has never popped off.
statusk
Ben
DMV
2024 Mustang Mach E Premium AWD ER
I usually thread the charger through the Velcro strap on the closed end of the door cover. I find that it pulls the door to just enough it kind of keeps the rubber insert in place.
DeusEx
New York
Wouldn't that expose part of the hinge? I've had the hinge freeze up on me a couple of times because the port cover directed some water towards the hinge and froze.
statusk
Ben
DMV
Haven’t had a problem with that the door cover has plenty of play so it still has room to pull flush to the body. Also I don’t pull the Velcro tight on the open end of the cover. Just had 6” snow with a couple inches of ice on top and worked just fine.
Wytwolf
Canada
yes similar to yours. the clothes pin gently pushes the cover to the right and in so that there is enough friction to stay in place. I think the clothes pin also pushes the flap to the left i think it's the wind that partially closing the charge port is what pushes the weather cover off. there is still the odd occasion that still still happens but before you sneezed in the next community, it would pop off.
