ChargePoint Charger - setting maximum charge % limit ?
stephanieag88
Stephanie
Boerne, TX
Atlas CrossSport, Tundra
Nurse
Just got my ChargePoint charger, and spend a whopping $1.48 charging, first time using it. But I went to 100% and the app didn’t seem to realize that I was at 100%, the FordPass App sent me a notification. Is there a setting I’m missing?
Edw
FI
Mach E
Same. Just wait for a while and the it will send you the notification
If you want to charge to 90%, you need to save the charging location in the car, then set charging hours, and the 90% limit.
Home AC chargers don't know state of charge of the car.
  • Like
Reactions: ARK
Agree with this.
You can also edit the charge limit settings from FordPass mobile app.
In either case, you will need to have a charge location saved in the car before it will allow you to edit the charge limit.
If you touch the little car in the upper left corner, then Settings, then Charge tile. That will bring up a charge settings screen where you can create and edit charge locations. Once you have a location programmed......and you are at that location then you can edit it.
My car will only let me edit the charge location settings from inside the car if I am at one of the locations which is kinda weird. FordPass will let me edit no matter where the car is located so each method has it's benefits I guess.
Good luck!
