Charging 20% to 80%, roughly how long?
circatee
Georgia, USA
Mustang Mach-E GT PU, 2025
Curious, if you’re at around 20% and using an L2 charger, roughly how long would it take to get to 80%?
Additionally, using those ‘fast’ chargers around the country, for 30 minutes or so charge, how many miles roughly would one get?
Thanks and sorry for what is probably a repeated question…
larryk
Larry
NC
Mach-E Premium on order
Could be as fast as 6 hours with the Ford mobile charger in a standard range (70 kwh battery).
hybrid2bev
2026 Rally
Miles is a bad metric for DC charging. Assuming ideal temperature conditions on a 150+ kW charger putting out full power….30 minutes is enough to get an extended range battery from 20 to 80 percent.
How many miles you can get from 80% charge depends on too many variables (speed, elevation gain/loss, temperature, wind, rain etc.) to give a specific answer.
AngryMan
Living the good life
Google Play Store has an app called EV Charging Time Calculator where you can punch in the particulars of the car, charger and charge rate . It might be what you're looking for
Garbone
Gary
Loafer
Full by morning. All is good.
About 6 hours on a 40A Level 2 charger.
Donna216
Donna
Cleveland, Ohio
2021 Mach e GT
Machinist
It would depend on the range of the car. I have a gt that has a range of 270 at 100%. When I charge from 20% to 80% it takes just under 8 hours.
On public chargers, 30 minutes depends on the level of the charger. On a level 3, it will add like 30+ miles in 30 minutes but a level 6 would add 150+ in 30 minutes.
Hope that helps.
OH2AZ2OH
Dublin, OH
Mach E 4X
Charge rate depends on battery capacity and amperage. I have Extended Range, and charge at 32 amps at home. I add right around 8% an hour.
RDub
Rob
VA
Ford Mach-E 2022
On our FME Select, it took about 45 minutes to go from about 25% to 80% on a DC fast charger.
thenew3
Central Coast CA
What is a level 6 charger? Isn't Level 3 DCFC? If you're only getting 30+ miles on a Level 3 DCFC in 30 minutes then something doesn't sound right.
Donna216
Donna
Cleveland, Ohio
2021 Mach e GT
Machinist
I use an app called "chargeway"
It describes all the chargers as "levels" based on kwh. in the area and the speed of charge. A level 2 gives me around 20 miles per hour. The level 3 gives me about 60 an hour.
Graction
Gil
Northern NJ
Rapid Red Mach-e GT
I just charged GT from 14-54% in 19m on 150kW charger which would extrapolate to 30m for 20-80 assuming rate doesn’t slow as it approaches 80.
VaporTrails
Southeast US
2023 MME GTPE Vapor Blue, 1995 Acura Integra GS-R
I agree with “full by morning”. I verified that my L2 EVSE would hit about 9.4kw and then turned it down to 4kw to reduce the load on the GFCI. My normal use-case is to charge one night per week. As long as it is ready to go by morning, I’m good. In retrospect, I probably would have been fine with a 110V EVSE, and supplement with occasional DCFC.
On your second DCFC question, I charged from 17-80% in 36min in 100 degree temps. On a recent road trip, I was surprised how rarely I feel like I am waiting on it. Only when a bank of 4 DCFC’s were maxed out did I note an annoying delay. To me, it is less about raw time and more about how I can use my time.
