- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
The surge protector has to connect through a breaker, so no. If you have 2-pole 20A breaker in your panel already, you could potentially use that if your breakers are listed for double-tapping (such as Square D). Otherwise you can make some space by replacing a couple 15 or 20A breakers with tandem breakers that use half the space. An electrician could probably make it work in your panel.Any options you're aware of as far as type 2 that does NOT require adding breakers? My panel only has one open slot left.
