- Oct 4, 2022
- SE US
- 2022 PB F150, MME GTPE
- Banned
- #46
I believe it's the way certain capacitors charge. "missing" return current that a cap is eating due to circuit design is notorious for tripping AFI, which operates similar to GFI. Anyone with AFI breakers can attest to nuisance trips when plugging in certain DC consuming electronics (or using a large motor, or if you're just talking trash about the breakers) will cause a nuisance trip.It does NOT give the reason for nuisance tripping as its internal GFCI. Because it’s not the reason.
That sentence is telling us two things:
1) Don't use a GFCI breaker due to nuisance tripping.
2) Don’t worry, because the EVSE provides GFCI protection (like all UL listed EVSEs).
Someone that's inattentive may plug in their car and think it's charging only to come out the next morning to see it's still got the same or less charge than when they plugged it in. That could be a bad situation if you needed more energy for the day than was contained in the battery. Sure it's the breaker's fault, but they're probably calling ford after taking to social media.
