Charging Target Stuck at 100%
RSF
2021 Mach E P ER
I have had my MME for 2.5 years, and have charged the same way the entire time. I plug in at home anytime and charge to 90%. Starting two days ago the Target Charge Level now says 100% and I can't do anything to change it. I looked back at past posts about setting preferred times and have tried that with no success. No matter what I do the Taget stays at 100%. Anyone else have this happen?
ctenidae
Alex
Stamford, CT
Solver of problems
If you smack it just right, you might be able to get the battery charge stuck at 100%, too.
Beyond that, I got nuthin'
DogNPony
Dee
Mustang Mach-E 4X, Victory Cross Country
IT System Engineer
Yeah pretty much had same thing happen and couldn't rectify via Ford Pass. Had to go to car, open the Charing Icon app, select Home (or whatever you named it) as the Location. After that, check Ford Pass to ensure Home is selected as your Charge location, and "use Preferred charge settings" is also selected and not "Charge when plugged in".
For whatever reason changes at Ford Pass were not pushing to the car. One of the recent updates killed something. After doing this my charge level again stops at the set 90%. Hope that helps.
djett
CT
Mach E Premium AWD
I'm sure you already tried this but generally my issues like this have been fixed when I update the charging percentage in the car. Even when I first started doing this vs using the app it wouldn't always "take.". But seems there was an update in the last couple of months and it has consistently worked better.
2022GrabberBlue
Cindy
NL, Canada
2022 Mustang Mach-E
Same thing happened to me a few days ago right after an update. I find that whenever Ford does an update, it changes at least one of my preferred settings - whether it is my charging setting, heat, etc.
