Climate control not working
Chapschaps
Oneil
CT
Mach E select Fusion energi
I’ve never encountered this issue before with my 2021 Select. When I press any of the climate control buttons for the AC, heated seats, or steering wheel, the climate control system is completely grayed out. Even the temperature gauge on the screen doesn’t display anything. I’ve tried pulling the fuse, disconnecting the battery, and even using the app to start the climate controls, but none of these methods work. The car is currently at the dealership, and they’re trying to diagnose the problem. They mentioned that they need to remove the dashboard to access the AC module. Has anyone else experienced a similar issue?
alexw
Alex
Los Angeles
2024 Mach-E Rally
Electrical engineer
I have not, but it would make sense if the compressor, a fan, or a pump was inoperable. As I understand it the Mach-E has a right slew of pumps for thermal management - I think as many as 4 on some years. I bet you'd get that kind of symptom if one of them was dead.
NY_Cade69
Cade
PA ON NY
Reddy Kilowatt, a 2025 Molten Magenta Premium Sport Package ER/AWD
Sounds like a hvac control module, a compressor issue wouldn't affect heated seats or wheel...
Might be as simple as a loose or corroded wiring connection, vehicle configuration issue, or fried module.
Chapschaps
Chapschaps
Oneil
CT
Dealership saying they have to take apart the dashboard to get to the module,I’m going to get a second opinion from another dealership before I commit to them taking apart the everything,because they are saying it would cost around $2000
NY_Cade69
Cade
PA ON NY
"Taking apart the dashboard" probably means removing the Sync screen, not the whole dash...
Chapschaps
Chapschaps
Oneil
CT
Do you think it would be a 10 hour job because that’s what the service rep was telling me over the phone,never used this dealership before the one I normally go to the tech on vacation,
NY_Cade69
Cade
PA ON NY
That sounds excessive, but I don't have access to a shop manual. They might be quoting a max figure based on removing the entire HVAC...
Chapschaps
Chapschaps
Oneil
CT
This is basically what happens when I press any button
