- Jun 24, 2020
- Vermont
- 2024 Kia EV9 GT-Line
I meant only 3 times this weekOnly 3 ????
"and it's only Sunday"I meant only 3 times this week![]()
Yep. Still plenty of room for improvement!"and it's only Sunday"
I am not sure how 1PD and CC work together - the point of any type of CC is to drive itself (accel/decel) without us touching the pedals unless we need to intervene. Do you find it better with or without 1PD when using CC.? I agree that once you get used to 1PD everything else does not feel normal.I used ICC from Tahoe to Reno (60 miles) and back. It’s a road I am familiar with and it has several speed traps. I set to largest buffer for ACC and set the speed to 2-3 over posted speed limit. I did not use the lane centering, not ready to give up all contr
Loved it!
two issues:
1. Learning. I was in one-pedal driving. With 1PD and ICC, your foot doesn’t have to be on the pedal. To turn off CC, you can tap on the brake like all other vehicles. With one pedal driving on, when you disengage CC with a brake tap, you better get your foot back on the accelerator or you will slow down pretty fast!I’m a new 1PD user so suspect a month or two and driving anything else will be odd.
2. for some reason, on a certain section of road, it thought it saw a 25 MPH sign and quickly decelerated from 45 MPH, the proper speed. I don’t recall any confusing signs like a school warning. Just a random slow down. Keep your foot close to override errant sign readings.
I was trying the combo of 1PD and ICC because of the 2000 foot descent, the thinking was 1PD might get more batt regen? Overthinking it?I am not sure how 1PD and CC work together - the point of any type of CC is to drive itself (accel/decel) without us touching the pedals unless we need to intervene. Do you find it better with or without 1PD when using CC.? I agree that once you get used to 1PD everything else does not feel normal.
I am not sure unless we all give these variations a try. I do think 1PD has more regen so in CC it should be generating more regen than without 1PD but thats just an assumption.I was trying the combo of 1PD and ICC because of the 2000 foot descent, the thinking was 1PD might get more batt regen? Overthinking it?
Not sure if OPD matters once in CC, some cars ignore that sort of setting once CC is turned ON. On exiting CC, you would end up in OPD or D depending on how you have it set (best guess).I was trying the combo of 1PD and ICC because of the 2000 foot descent, the thinking was 1PD might get more batt regen? Overthinking it?
