Does the Mach E charge while waiting to charge?
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
Why not just plug in every night so that it doesn’t need to charge prior to the hours you set up.
I’ve have been doing that lately. Mostly because I don’t like prison bars. ?
AliRafiee
Ali
Seattle WA
Software Eng.
That is an option but I try to keep my "cycles" as low as possible. Will look at charging when I am at 30% instead of 20%. That way it just needs to go from 30 to 80, which it can hopefully do inside six hours.
A charge cycle is from 0 to 100%
If you do 10 10% charges, that’s one cycle
EMachE
Enzo
YEG
Mach E, Escape Hybrid
Mechanic
I plug in every day during the winter and then once a week in the summer. My commute is about 10 minutes one way.
krafty81
krafty81
Terry
2021 MME AWD EX Premium, 2023 Lexus RX350h
I saw yesterday that I could let the car pick charge times base on what the best times were as published by the power company. When I first got the car this was not available for my power supplier. Are you you using time you selected manually or did you use the automated option? If yo IM here uses the automatic one they may be your answer.
As I mentioned above, my FP does not show my plan for SDGE. NEM 1.0/TOU5
737flyer
Richard
Redington Beach, Fl
2025 Mache Premium, 2024 BMW IX50
Retired Airline Pilot
I set the charging hours on my ChargePoint home charger and not the car. This way it never starts early or overruns.
Blue highway
Oregon
Mach E Premium SR RWD
Cycles are counted differently than you may be thinking.
Battery charge cycles are counted from 0-100% = one charge cycle so charging once from 0-100% counts the same as going from 50-60% ten times. The so-what is that waiting to drop to 20% does not reduce your charge cycles.... and shallow depth of discharge is better for your battery than deep discharge at the same cycle count.
Anyway - if you charge every day, you will rarely if ever need more than 6 hours to charge... presuming you are able to charge at 32A or better. Aaaand you are doing your battery a favor by reducing depth of discharge on average.
krafty81
krafty81
Terry
Thanks for all the help - problem solved!
TheSteelRider
United States
'21 Premium RWD
As @AliRafiee commented, that's not how "cycles" are counted. One "cycle" is 0 - 100%. If you charge 50 - 80%, that is 1/3 cycle. If you charge from 50 - 80% three times, that is one "cycle".
In fact, if you are trying to really nerd out on charging, you are doing the exact wrong thing by deep cycling like that.
See the video in the first post here: https://www.macheforum.com/site/thr...m-your-ev-battery-engineering-explained.33402
TL;DR it is better on the battery to charge more often in between a smaller percentage range than less often across a larger range.
