Driver door does not open when I approach the car
Sleep7
Sam
new york new york
Mach E
Doctor
Hi. I'm sure other people have had this happen. Recently when I approach the car the drivers door will not open. Only the rear passenger door will open. I haven't tried any other door. I called my dealer but they don't have a an appointment on Saturday. So I won't be able to go for a while
Sleep7
Sam
new york new york
Mach E
Doctor
Yes I'm using the key fob. I wish ford would just send me an over the air update to fix this.
Sleep7
Sam
new york new york
Mach E
Doctor
Disconnect and then reconnect your 12v battery. I had this exact same issue, dealer told me I needed a new door latch module. I disconnected the 12v battery and it is fixed.
Did that and it solved the problem. I hope the problem doesn't come back! Thanks
americanflannel
Va
Mach-E Premium AWD ER
I do not write menu descriptions for a living
My door quit this week.
how exactly do you disconnect the battery?
Crilly
Dale
Hartland, Wi
Livewire prius prime Mach e. In 3 weeks if it was built yesterday
The positive with a 10 mm wrench is the easiest to reach.
ericNdfw
Eric
DFW, TX
ericsmalling.com
`21 MME Prem 4X w/GTPE wheels,`22 Hyundai Palisade
Solutions Architect (software)
Ugh. Mine started doing this again a couple of days ago. PITA to get to the battery but better than driving all of the way to the dealer I suppose. Will try it tonight
UPDATE: Did it last night and it worked but, interestingly, the car then proceeded to charge to 100% that night instead of the 90% I have set up for my home charger. I checked the charge settings and it still shows the 90% target. We'll see if it returns to stopping at 90% tonight I guess.
rbott
Richard
New York
I'm having this problem on our new MME. For the folks who disconnected and reconnected the 12V battery, has the issue come back since doing that?
ericNdfw
Eric
DFW, TX
ericsmalling.com
Tonight will be one week since I did it and it has not reoccurred.
