Driver Side Window
fpasta
I've seen to have lost the auto up feature. Is this is even toggleable. Auto down works, the other windows auto up works.
I use this feature alot.
Neil4Real
That's normal, they use soft start and stop now for every cycle.
This is the calibration procedure:
  1. Start the engine.
  2. Press and hold the window control switch until the door window is fully open.
  3. Release the window control switch.
  4. Lift and hold the window control switch until the door window is fully closed.
  5. Release the window control switch.
  6. Lift and hold the window control switch again for at least one second.
  7. Press and hold the window control switch until the door window is fully open.
  8. Release the window control switch.
  9. Lift and hold the window control switch until the window is fully closed.
  10. Test for correct window operation by carrying out the one-touch down and one-touch up features.
fpasta
fpasta
Thanks, it worked!
