Drivers door got keyed.. ?
jericho
Jerry
Pacific Northwest
c8, Red '21 FE Mach E (traded), '23 Red GT
Must been some EV hating person. There is a keyed line going across the drivers door. I’ve been looking at you tube videos about a fix but thought I’d reach out to see if anyone has advice on what I should do - bodyshop or diy?
RetiredDP
Camino, CA
Focus RS
To help prevent this, I got the Ford Mach-E car cover (fits all, including the GTPE).
Kabish
2021 Mach-E Mustang
DYI will never be perfect. If you are someone that can only focus on the one tinny little scratch on your cellphone display, then a DYI might not be the best route for the MME. While you can defiently do it, they are very seldomly perfect and you can tell its been touched up.
A shop will put your car back to looking like the day you bought it.
Nklem
Norm
Coast of Maine
Subaru Solterra
Mechanical Engineer
Use a shop. I believe it’s a comprehensive claim so maybe a lower deductible.
jericho
jericho
Jerry
Pacific Northwest
Happened while I was out and about, so a cover wouldn’t have helped unfortunately
Scrannel
Malibu, CA United States
Range Rover Sport Diesel. Tesla Model 3 Performance
Screenwriter
Sorry this happened to you, I fear it's going to become a trend again. I remember a lot of Tesla owners were putting plate frames on their cars reminding fools that the Tesla is an American car. But to go after a Mustang..? We are reaching new lows.
TheVirtualTim
Dearborn, MI
Park as far away from business entrances as possible. Most people wont make the effort to walk out to a distant space just to key a car. But they might key a car if they happen to be walking right by it.
jericho
jericho
Jerry
Pacific Northwest
Is it a clearcoat scratch or went through the paint?
Some parts seem deeper than the others, it may have gotten to the paint
GoIrish
Los Altos, CA
Mustang Mach E Premium AWD Ext Range
if you wipe it with isopropyl alcohol or water, does it disappear?
jericho
jericho
Jerry
Pacific Northwest
its been raining... so with water it's still there. i don't think alcohol will work either, you can feel the scratch with the fingernail.
GoIrish
Los Altos, CA
My 2 cents, don't get the door redone first...report to insurance so that you fulfill criteria for timely reporting. Then buy some touch up paint from the dealership and follow these steps:
- wet sand area with 3000 grit
- clean with alcohol
- fill scratch with touch up paint using toothpick or fine paint brush, wipe excess with a razor blade
- do this 2-3 times and sand excess away using 3000 grit
- When sanding, apply ZERO pressure and don't sand too far away from the spot, don't increase your work
- apply clear coat that came with touch up paint
- sand this down too
- apply polish using drill foam applicators (very inexpensive on amazon)
If unhappy with these results, call insurance and book appt.
