DRL Running Lights not working
Ned
Ned
Prescott, AZ
waiting for ford
This is new. Worked ok in the past.
Daytime running lights are selected on, but both front and rear lights are out.
Its a 2021 Premium, rear wheel drive.
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
And you tried toggling it off and the back on?
DRL are only on at the front.
DRLs on the MME are only on when the car is in gear. They are not on in Park. 🐩
JohnFoxeSheets
San Francisco
johnfoxesheets.com
Yes, cycled it twice.
You could try disconnecting the negative terminal of the 12V battery, letting the car sit for about 10 minutes, and then reconnect the battery. This will reset the modules of the car (don't worry, they'll not lose their programming). However, if you have already had the recent 12V charging recall s/w installed, you'll need to wait at least 12 minutes after powering down the car before you do the disconnect.
tbrumleve
Tom
Oregon, USA
Check your settings in Sync. I believe they can be disabled / enabled there.
Not sure what you “cycled twice”, so just putting this out there.
Ned
Ned
Prescott, AZ
waiting for ford
Sorry for the false report. The lights are on when in Drive. My bad. Thanks for the helpful replies.
