Drying the brakes.
Carsinmyblood
Mitch
Western NC
Self employed
Remember when we used to have to gently apply the brake peddle to drag the brakes to dry them after hitting a lake at the side of the road?
How is this accomplished now? There is no indication on the dash that the brakes are being applied vs regen.
Wish list: small indicator on the dash indicating when you're actually braking.
noway
Norway
2021 Mach-E First Edition
Software developer
If you need to do this manually you can temporarily switch to N/neutral and use the brake pedal as normal, it will not use the motors at all when in neutral, just the friction brakes.
Other than that it should do this automatically, otherwise the brakes will be destroyed by corrosion. I think it is supposed to mix some friction brakes into the mix just for the purpose of maintaining the brake discs.
highland58
IT Solutions Architect
After I wash my car at home and park in the garage, the next time I drive it my brake shoes are stuck (rusted?) to the rotor and release with a loud noise. The brakes make a scraping sound for a short time, as the rust gets scraped off. The next time I wash my car, I will drive it for a few minutes to (hopefully) remove the water from the brakes, before I park it. There is a hill right outside the neighborhood, I can go to the top then back down at 40-50mph, that should throw off most of the water by means of centrifugal force.
Does regen work in reverse? In the old days you could adjust drum brakes by going in reverse then hitting the brakes hard. I'm wondering if that would use any regen or just brakes, if it would effectively clear the water off the brakes.
ZuleMME
Zule
Denver, CO
21' Job1 P4X MME, 22' MYP
Implementation Engineer
Audi's have a problem with squeaky brakes and the answer is always to go do a spirited driving acceleration and brake. If they can do it a Mustang can do it. Just drive like you want to put those nay-sayers in their places. :)
This was more necessary with drum brakes than with discs, as the rotors tend to sling the water off better than the drums.
That said, it's still necessary with disc brakes after a good dunking. I always drag the brakes on my Blazer after a crossing (aftermarket rear disc brake conversion).
MY21 J1 Premium RWD SR
I expect regen is the same forward or reverse. But if you press hard enough on the brake pedal, you'll also be using friction brakes no matter what direction you're heading.
