Experienced powertrain failure reduced power
Greta
Rebeca
Miami
Mustang Mach E
Has this happened to someone? Powertrain failure reduced power
Clear the message from the screen (hit OK button).
Turn off the car, turn it back on, see if it goes away.
If it goes away, watch for its return.
If it comes back, call the dealer.
Also, check to see if the little wrench is showing on the driver's screen.
Greta
Greta
Rebeca
Miami
Mustang Mach E
Thanks. The dealer fix the issue.
Crilly
Dale
Hartland, Wi
There are two reasons to keep car plug in or on when not in use. One it can keep battery at a nice temp. This forum does not talk about keeping the cells balanced. But they need to be from time to time.
BMT1071
Glendale, AZ
21 MME SR RWD, 23 MME GTPE
EV Technical Trainer
