Don_23805
- Don
- Feb 14, 2021
- Central VA
- Honda Ridgeline, Prem MME DMG AWD Ex Batt
Thanx. All the connections are real tight. Will check with IR camera when charging later. 30 amps for a long time is an unusual load around here.If it happens again, try unplugging the charger from the wall and plugging it back in. If the charger then starts up, it's a charger problem.
If that doesn't work, it might be a problem at the breaker, which would likely be a loose connection in the breaker box, which is something you would want to get fixed right away. I'd go so far as to recommend turning the breaker off and not using it until it's fixed.
