- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
Have the A/C automatically run when the cabin temp gets above 122ºF/50ºC to protect the displays and interior components from overheating damage. Less failed displays. This will also reduce the amount of time it takes to cool down the cabin when departing and will allow BlueCruise to work more reliably in extreme climates (the front camera can overheat). This feature can be invisible/built in and completely automatic, but it needs to function while unplugged.
Optionally, give the customer the option to lower the setting if desired (down to 95ºF or something) for use in more mild climates.
Also have the battery automatically cool itself while unplugged if it gets above 113ºF/45ºC. Needing to plug in to keep the battery cool is is a bother for extreme climate dwellers.
Yes it takes some battery to do the above, I don't mind if my % goes down a couple while parked during the day. Phantom drain concerns are typically overblown, it would only use ~5% per day, and realistically the only time it's an issue is if you park at an airport for a week. In that case, automatically disable overheat protection if the car has been parked unplugged for more than two days. And disable overheat protection when the battery is less than 15% so it doesn't drain completely.
