- Jul 1, 2021
- SE MI
- 2022 Mach-E Premium 4X, 2022 Lightning Lariat ER
Moved from a Fusion Energi (MyFordMobile) to the Mach-E (FordPass).
- PAAK is ridiculous. Wife's phone won't setup. Ford should issue a 2nd fob to all current owners.
- Charging times setup fine (my peak is 11AM - 7PM M-F). Plugged in just before 7PM last night, and charging began with 60% battery and no departure times setup. Same happened with Fusion Energi. Will be on the phone to Tier 2 support today.
- Remote start wouldn't work once due to vehicle going to sleep after sitting for a whole 45 minutes.
- Sync 4A nav voice doesn't turn radio volume down enough to hear unless you crank nav voice up which you can only due while she's talking.
- Ford is not clear that there are 2 bluetooth profiles that get created - one for PAAK, one for Sync.
- No watch app for FordPass, yet there is one for MyFordMobile?
- Need full list of settings that are saved in profile. What's so secret?
- Should be able to copy profile and then edit it vs. having to set everything up.
- Bought the cargo rubber mat. Note it only fits when the existing cover is in the lower position. In the level load position, it's about 1/4 inch too big.
- 110 doesn't give 3 miles per hour with 60% battery. Even less.
