Ford Pass question…
2021mustangdan
ON, Canada
2022 Mach-E Select RWD, grabber blue
I see there is remote start on Ford Pass app on my iPhone, as well as windows up/down, frunk button, lift gate button etc.
But where is the setting to adjust the air conditioning, heat when you what it before you go to your vehicle.
Taking delivery of my Mach-E on the 14th of May
thanks
When you remote start, it uses settings in the vehicle, either auto or last.
When you set a departure time, you pick one of 3 settings.
Neil4Real
thanks
Settings inside the car - vehicle or general, I think, then "remote start" - Let's you select last or I think cool/warm.
Illinibird
Frankfort Illinois
I had 21G01 done on my car last week and Blue Cruise was also added and works. What I don't have and wonder why is that there is no frunk button either in the Ford Pass or in the car (in settings). Am I missing something? Did the frunk button appear in the later OTA Startup updates? Why is it not present in my Ford Pass app?
2021mustangdan
2021mustangdan
ON, Canada
I attached photo from my Ford Pass app
Ford Mustang Mach-E Ford Pass question… 5EE8883B-5F79-4F49-BF4C-9FC4D199F178
Electronic frunk opening still hasn’t been added to Job 1 cars. Some may have the button, but it doesn’t do anything.
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
Highly recommend going into the settings of the big screen and setting climate on remote start to “auto.” Then if it’s cold out the car will start to warm the passenger compartment when you remote start. If it’s hot out, the car will start to blast the AC when you remote start.
You can also pick “last settings.” But then if you’ve got it warm and you’ve turned the heat down, arrived at your destination and turned the car off. It gets cold overnight and you remote start the car… it remembers that the heat was off.
