janstubbs
- jan
- Jan 3, 2025
- san marcos ca
- 2022 Ford mustang Mach E select
- retired
I have Base Model Mach-E. I posted a photo of orignial front tires worn out on inside edge about a year ago, at about 30K miles. Note that these Michelin tires are warranteed for 60,000 miles if you buy them aftermarket.Any news? The inside of the front passenger-side tire wears out faster on my car.
It has happened to me twice already, and the alignment only lasts about a year.
I only drive on highways and haven’t hit anything.
2021 job1 awd
I had alignment checked, it was in spec. Everyone will immediately suspect too much negative camber, but specs set that to near zero. Dealer had no answer except to rotate more often. Higher tire pressure than normal might help.
This needs a factory response.
