louibluey
- Joe
- Dec 21, 2020
- NY
- FE "Louibluey" GB
- retired
Or, a jump pack might work fine too, we disagree on this one.yes, the frunk-popper bumper leads will ONLY work if LVB is too dead to energize the door locks to open the doors. I hope you have set/memorized the 'manual' door code to get into the cabin if you lose or damage your phone/fob?
if the LVB is indeed dead you are going to need a 'jump' from a running vehicle for a good 15 minutes to get enough energy into the LVB to get it's voltage up high enough to restore functionality to 'start' the MME at which point the HV should take over the task of charging the LVB. So stashing a pack of AA batteries under the bumper is probably a waste of time since there would be a vehicle there already to give you a jump.... after you remove the beauty panel(s) to gain access to the jump points.
