corradoborg
- Mike
- Jun 9, 2023
- Aptos, CA
- 2025 Mach-E GT
Guess I have very sensitive fingers, as the detents are utterly obvious to me. And again, going from reverse to drive, you don't even need to count detents. As long as you get past neutral, you're in drive, even if you spin the dial a bunch of detents beyond.It is far too easy to miss your target click because the detects are pitifully vague. If you drive at 98% like I sometimes/often do you don’t have time to carefully braille your way into another gear selection. Give me the stick that came with my T/A that can be set to give you one gear position change while hammering corners, braking, using the go pedal, etc. for an automatic any day of the week over the abomination that Ford foisted upon us. Yes, I can use the rotary shifter and regularly do without looking at it (who said I had to look at it?), but it’s an effort that I would rather spend driving than trying to figure out. It just does not belong in the GT.![]()
And I must be a timid driver, too, because I can't imagine ever needing to change gears so fast that the dial would be a problem. The limiting factor to me seems to be the transmission itself. If I try to change from forward to reverse (or vice versa) too quickly, it clunks around and makes me uncomfortable, thinking I'm going to break something. Are the GT's transmissions that much better that this isn't an issue?
Maybe once in a couple hundred instances, so not a lot. Only after a song is played way too loud does my brain re-engage to correct. Sharing that Ford conducted human factors research to conclude this positioning would not be problematic would help me as a user understand this positioning. Provide the customer a comfort level!
