GPS simulator and work destination
FordMachET
Robert
Sweden, Gothenburg
Mach-E
Hello,
I got two questions.
1. What is GPS simulator?
2. Is it possible to set a work adress and get notifications regarding traffic etc?
FordMachET
Robert
Sweden, Gothenburg
Mach-E
Also:
Is it possible to remove a single MyTrends entry?
What is the difference between "Destination Suggestions" and "Predicted Destination Alert"?
Eric_C_Boston
Eric
North Shore, MA, USA
Retired Software Engineer
A lot of GPS units have the simulation feature. It will basically simulate driving a route at the speed limit.
SpacePony
Kansas City Metro
2021 Mach-e Preimum AWD Ext. Battery
Also:
There sure is a way to delete a single myTrends entry. Just go to your MyTrends page within the nav, then select the destination you want to remove, and on the page with "GO!" on it, touch and drag the lower panel up so that you can see a trash can icon.
So, should it be on or off. What do you think?
It should be off if you actually want to use your GPS nav. It prevents the normal use of the system because it's simulating the GPS location and driving the route.
