Had it one week, charge door won't open
scott_77
Scott
2024 Mach-E Premium 4x
You can try applying a winter blend of windshield washer fluid around the seam of the cover
rhfritz
Rob
MD
2021 MachE
Early on with ours, pin-capture mechanism behind the hole in the plate broke, and the dealership had to replace it. But our problem was that the door wouldn't close. If expanding frozen liquids somehow bent your pin, no amount of any bodily fluid is going to fix it. As others have suggested, attempting repetitive light "percussive maintenance" with the side of your fist directly behind where the pin is located is your likely best bet until you can get it to the dealer. Since that panel is plastic, I'd be careful with a heat gun.
MellowJohnny
Christian
YYZ
Solution Architect
If you've got a heated underground parking garage nearby you could try that. Park for a few yours then give it a try.
SWO
MD, USA
I've had some luck putting a small application of sil glide to the mechanism when winter hits. Lubricates to -20 and keeps water/ice out.
WPJoe
Acura RDX
This happens to many people.
For me, I poured warm (not boiling) water from a tea kettle near the corner seam and after once or twice, it opens.
Once it opens and dries, forum advice has been to spray a silicone lubricant in the latch hole to prevent additional freezing... So far that's worked for me.
