Driver's side rear door won't open without opening driver's door?
p-zilla
Denver, CO
Ford Mustang Mach-E4X
Hey all, I just had this problem start happening a couple weeks ago. It's not a huge problem, just annoying when getting my kid in the car to open my door and then his. Any other people with this problem? Is it already covered by a TSB?
christooma
Nashville, TN
2021 Mustang Mach-E Premium
I actually just noticed this same issue yesterday for the first time. Thought it was maybe a one off thing. Will be curious to see if more owners chime in about this.
Silver Surfer
Washington DC
Mach E
It's a known issue im at the dealer now hoping that updates will fix it btw none of my doors open without unlocking with the fob first.
Customer Satisfaction Program 21P22 – Software Calibration Update includes updates to all door modules.
Stormtrooper
Knoxville, TN
2021 Mustang Mach-E AWD Ext
Had update 21P22 installed Monday and the this problem disappeared - but came back today. I'll report it, but I'm not expecting much to happen anytime soon.
Other 21P22 observations include the GOM tracks much closer now. My morning commute is ~ 22 miles and the GOM reports 23-24 miles range used. I precondition, morning temps are in the low 30's here.
When charging at home (220V), there used to be a noticable hum from the car, sometimes accompanied by fan noise. Now the car is extremely quiet while charging. The first time I charged after the update I had to verify the charge light was blinking on the car and EVSE to make sure something was happening.
Jeffvisor
Jeff
Harrisburg, PA
Ford Mustang Mach-e
There is a way to fix this at home. I had this same issue really bad would never open front door always had to open back door first. The way to fix it is access the 12V battery in the Frunk by removing the panels on the driver side. Take a 10MM wrench and remove the 12V battery terminal on the Positive side for a min. Put it back on and it fixes the issue. Only downside is it resets your GOM but that will come back to where it was when you drive a few hundred miles. It works I read about it on here and did it myself took less than 10 mins those panels come off easy and so does the terminal.
Neil4Real
That is so good to hear regarding the hum. Mine is getting the recall and 21P22 completed, the hum was crazy, but I thought it was normal until I saw a few posts. I didn't think that it would go from that loud to super quiet! That's fantastic. Hopefully the fan or whatever still kicks on when it needs to.
p-zilla
Denver, CO
There was a TSB for the fan hum while charging that i had applied when they replaced my Power Steering Module that failed.
Jeffvisor
Jeff
Harrisburg, PA
Ford Mustang Mach-e
Its TSB 21-2288 it totally fixes the fan noise becomes very quite after this fix is applied.
MikeBeeman
Mike Beeman
Chicago
2023 Mach e premium RWD standard range Vapor Blue
IT Analyst
I recently started having the same issue: rear drivers-side door won't open unless I open the front drivers-side door first. It's a one-off kinda thing -doesn't always happen. This is a 2023 Mach e, a little more than a month old, so I'm sure I have all the updates. I'll check back to see if there's a fix
2FlyMache
Patrick
Martinez GA
2021 Rapid Red Ex4 MachE
Mine too. A couple of updates ago and my PAAK wouldn't work anymore. Deleted it and set it up again and worked for maybe a week then nada. Just use my Fob now
Ford Motor Company
Official Ford Account
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.
