cemald
- Cemal
- Feb 17, 2025
- Trumbull, CT
- Ford Mach-E
Hello all. My driver side headlight on the Mach-E stopped working. The dealer is telling me that it could be either the headlight control module or the headlight assembly, which are two separate parts. Without knowing which one is bad, they are suggesting to change the headlight headlight control module first, which is $900, and if it does not fix the issue, then change the headlight assembly, which is about $1750. The issue is if the issue is the headlight assembly, then they will be changing a perfectly good headlight control module, which will cost me $900. It is weird that they have no means to know what is broken without trial and error and changing parts at my cost.
Anyone had this issue? Does anyone know where the headlight control module is located? I can try to order a used one and change it myself to see where the issue is.
