How To Never Miss An OTA Update Again
Bonehead
Malibu
'25 MME GT Performance ('21 MME Premium AWD Ex)
Every Tip & Trick.
I've tried your suggestion a couple of times now. For some reason, when I come back to the car several hours later I find that it's powered down, even though I turned off the Vehicle Power Down Timer. When I check the timer I find that it's been turned back on.
CarGuy11
CarGuy11
Pittsburgh
2022 MachE4X Prem, 2020 GRSupra, 2016 Corvette Z51, 2024 Emira
Be sure you are not plugged into a charger while doing this. You car should be started (press brake) & ready to drive when you leave it on. The switch resets on every start so set it and leave the vehicle.
Bonehead
Malibu
Thanks, I was in accessory power
azerik
Chandler/Flagstaff, AZ
DevSecNetOps, General PITA
Likely stuck as well since you haven't received an update since Oct.
Same here but I have received both -chg updates.
