Hum & Vibration While Charging
Paddler
Doug
Richmond, Virginia
Mustang Mach-E Premium w/Ext. Range Battery, RWD
I just installed the NEMA receptacle and have the charger that came with the Mach-E charging my Mach-E. There is a low hum and a slight vibration around the area where it plugs into the car. Is this normal? Everything else seems okay. The plug into the vehicle is barely warm as is the NEMA receptacle.
breeves002
Sam
St. Louis, MO
2021 Mach-E GT PE
The onboard AC charger is water cooled. You're hearing the water pump running. If the ac compressor is running to cool the battery you will hear that too along with the radiator/condenser fan.
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
These things make a lot of noises while they charge, or even when they’re not charging sometimes. Very normal.
