Ice and Mach E doors
We have all read that the door opener will break the door open after an ice storm. With all the wonderful winter weather, has anyone had ice freeze over the door buttons?
Yup. I pushed on the ice that was covering the button and the door busted through the ice when it popped open. I was impressed.
methorian
Roanoke, VA
IT Admin
I thought I saw someone question the buttons being heated. There was a picture of an iced/snowed over Mach-E and the area around the door buttons were clear of any ice/snow.
Maybe it only works if you pre-condition/etc though?
I noticed the possible issue at the end of last winter - we had a bunch of sleet the piled up on the door handle/winglet and covered the button. Luckily it hadn't frozen solid yet, but I added a comment to that old "wish list" thread that fordpass should have a "release door" button just in that case.
Logal727
C
Yeah the door buttons and sonar sensors are heated it looks like, but I think the vehicle needs to be remote started or preconditioning
hawkeye3point1
NH
Believe this is the case. As usual our first snow went to rain and then froze leaving about an inch thick ice crust. No sign of melting around the button.
I had not remote started or pre-con'd.
Gullwingdmc
Chip
Boston, MA
I have been waiting for a good iced over day to try this (and record it), but thankfully we haven't had one yet in MA.
Fixbear
Frank
ADK. foothills, NY
We had a ice storm that left about 1/4 inch on the MME. We most always precondition due to the ambient temps and low winter range. It did melt around the door button, but not all the way. broke off easily though. However, Used Ford Pass to open the back hatch and it tried but stopped. I thought it just hadn't gotten the command, so I hit the open button. It opened, but tore off the weatherstrip on the left side. They actually call it a sensor. The front end just slides in a slot, but the back has a push rubber tit that is kind of small. Ford did replace it no problem. Once they got it.
Guy
Guy
Canada
Premium AWD Long Range
The doors work very well in winter.
Fixbear
Frank
ADK. foothills, NY
I agree that the doors work well in winter. But the charge port door should open vertical to protect the connector from ice and rain. During the ice storm we went through the EVSE (GrizzlE Avalanche) faulted from the moisture in the charging plug. Glad I put the 110 GFIC next to the EVSE so I could dry it out with a heat gun.
