markboris
Sonora, CA
Sorry if this has come up, I'm only on page 3 of 7(!), but it will include the CarPlay screen if you take a screenshot of your phone with CarPlay active.
No it does not in iOS 26
markboris
Sonora, CA
Go to Settings > General > Screen Capture and toggle on the "CarPlay Screenshots" option
Yes you can do that and it works. I miss understood your question.
stellman
Austin, TX
2021 Mustang Mach-E GT
Tempted to install Beta 4 that came out today.
For the people that installed it, is the actual EV routing any different? Can you get a route, have Apple Maps pick the charging spots and then edit the charging stops?
markboris
Sonora, CA
I have been using iOS 26 since it came out the beginning of last month. Not able to edit the charging spots but It usually will give me a few alternates that either have different charging spots or none at all if I can make it to my destination.
I usually pick the route with no stops and if I need to add one, I'll pick it from the list of charging stations.
Ford Mustang Mach-E iOS 26 CarPlay on Mach-E IMG_7428
Ford Mustang Mach-E iOS 26 CarPlay on Mach-E IMG_7430
Ford Mustang Mach-E iOS 26 CarPlay on Mach-E IMG_7437
There is a new display setting which optimizes the resolution to fit the screen it is being projected on. It looks so much better and packs a lot more on the screen, 4 rows of icons even. With the higher HD resolution is looks more like my phone display except larger.
Ford Mustang Mach-E iOS 26 CarPlay on Mach-E IMG_7433
Ford Mustang Mach-E iOS 26 CarPlay on Mach-E IMG_7439
Ford Motor Company
Official Ford Account
CraigS
Craig
NZ
2023.75 RWD
Software Developer
The two things I am hoping for on CarPlay is being able to pick a location by touching the map, and pinch-zoom. I read that multi-touch was being enabled for 3rd party iOS apps soon, hopefully that means Apple are building it into their own ones now
