- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
Charging the 12V battery up to 90% can take several hours sometimes. People would wonder why their car is taking so long to finish charging.Seriously? It would just charge until both 90% LVB and charge limit of HVB are satisfied, and then it would shut off as usual. No energy wasted at all.
Yup, that will do it. That's why I don't recommend dash cams that run when the car is off. You're going to cycle your battery to death.But then the traction battery would sense that that 12v battery was low and charge the 12v. That would activate the DashCam again, and the magic box would allow it to run until 11.5 again.
endless loop
this kills the 12v battery.
So maybe the Mach E only charges the 12V when you are charging so this kind of thing doesn't happen.
So you have to understand the Mach-E doesn't have a trickle charger. It's either on or off. Full beans or no beans. Only way you can do something like that is to Level 1 charge on 120V so the car takes a long time to finish.If my car is plugged in and the HVB reaches my 85% target but my LVB is at 60%, why not top off the LVB? Especially, if updates rely on a certain LVB SoC.
The energy needed to maintain the LVB is negligible. If my car is plugged in, why not use it as a trickle charger?
I'm not disagreeing that they should improve the 12V strategy, there are just engineering limitations that make it so it can't operate like you think. If they do an OTA pre-charge, you're probably going to have to let the updates install on a schedule rather than the instant you see them pop up. And they would only go to 90% full, the last 10% takes too long.
Process has to be:
Wake up modules > Charge 12V battery at full amperage (20A idle load the whole time) > 12V reaches 90% > Shut down modules
