FrozenNorth
I'm wondering if a few members with an OBD2 reader and a Mach E with the LFP battery can post what they get at 100% charge for "energy", HVB Voltage, and HVB voltage variation?
At the end of charging to 100% (measured 3 or 4 hours after it stops) I'm consistently getting 65kWh, 378 to 382V and about 0.065 to 0.080V HVB module variation. Once I drive even a little bit the variation drops to under 10mV, and all the way down to 10% charge it's around 2 to 3mV. I've done several readings right after charging stops and then again 4 hours later and the voltages and deltas are about the same so it seems the BMS does not balance any cells after charging stops, it basically stops doing anything (so why is there a wait 4 hours in the BMS instructions?)
I'm asking because my SOH read on the carscanner app is really low, and after several "BMS reset" cycles (several to under 10% charge) SOH dropped even more instead of going up.
Also, my L2 charge rate (50A circuit) seems stuck at 5 kW, it used to be 8.9kW. unrelated coincidence?
(edit: I'll add, its a 2024 with 26,000miles, I bought used in late March, and I've charged to 100% 26 times in 3 months and 4500 miles and still got the Ford notice to charge to 100% monthly, lol. )
