Lifgtgate won’t open
siddhantnigam
Siddhant
Fremont, CA
Mustang Mach-e
I have a 2022 Mach-e route 1. The ligfgate has stopped opening from the screen. Also, when I walk to the car and use the button on the liftgate to open I just see amber lights blink. However, when I unlock car from keyfob and then press the button on liftgate, it does open. The screen button doesn’t work at all. I do see button for frunk to work. Any workarounds?
Try rebooting SYNC, after that I’d consider a 12V reset.
Ford Motor Company
Official Ford Account
Hey there. I can look into your Mach-E’s liftgate concerns on my end if you’d like. Will you send us a private message with your VIN and dealership info?
kdonnel
Metro Atlanta
2022 CA Route 1, 2020 Bolt EV
I think you are going to need to pull the 12v negative terminal.
My car got into a similar state some time ago. In my case I could not open the liftgate until I opened any other door first.
Pulling the 12v negative terminal and forcing all the modules to reboot fixed it for me.
There is probably a single fuse you can pull for a bit as well but I don't think anyone has ever said exactly which fuse might help.
