Help charge door won’t close
Joseph
Long Island NY
Rogue
I’m not able to close my charge port door. I looked at both the male and female parts and they look good. Has been fine for the last year and a half. When I push it in I get the normal resistance just doesn’t “catch”.
looking for help to fix or temporarily fix it until I can get it in for repair. First appointment was for Feb 7.
mach-ebert
2021 Mach-E Premium FE
Technology
If it's due to cold temps, you can try squirting a little isopropyl alcohol on both the male and female parts. That worked for me when it got some moisture in it and froze. YMMV
AKgrampy
Fairbanks, Alaska
If lock deicer fails to do the trick I would suggest painters tape to hold it closed! I assume you do not have a garage.
Ghost Ryder
LA
Tesla MYP, 22 GTPE
I remember someone replaced the male part. It comes from BMW. Easy, cheap fix.
Shayne
Northern Ontario Canada
2021 MME4x Prem
I find warm cold causes a problem with the door wanting to close easy for me. I know I am out this morning and after the last time will need to take the hairdryer out prior to trying to close it this time.
TimW
San Francisco
Mach -E
My wife’s Mach-E had that same problem a year ago in warm weather. This fix may not apply to you. However, pushing back the black rubber boot that surrounds the male part several times worked for us. Also ensure that you’ve used enough gentle pressure to firmly close it.
Art
Art
244SnowyGv932nFordC
Mustang Mach E
Retiref
This is one of the annoying parts on the MME. What I usually do is pull the flexible rubber back towards me and then push the door in and it works.
Shayne
2021 MME4x Prem
-18C (0F) here took the hairdryer to it and did make sure the rubber accordion was thawed and moving free. Still a bit stubborn to close but still working and not broke yet.
Spray with water displacement and then with PTFE
Water may freeze before hitting the port ;). I would say no water maybe lock deicer?
Teslaeata
Nottingham, England, UK
Noooooo, not water, water dispersant to expel the water? then some lubricant with some staying power that don’t clog hence PTFE.
skuker
Scott
NJ
2021 Mach-E Premium Extended
This happened to me this week. The Female side pushed through the panel Dealer replaced the whole assembly under warranty only took a day.
