Charge Port Door Backwards
Hammered
SE US
2022 PB F150, MME GTPE
All things equal, I'd rather back in. Depending on where it's at, it's easier to leave the road backwards than it is to back into (visibility dependent). If you're going to be loading it makes sense to orient the back door where it's easiest. Unless you're drunk pulling in, you're going to likely be more attentive on arrival than departure. Cameras make it real easy too -- use them.
dbsb3233
TimCO
Colorado, USA
Not in my case last night. I was at the EvGO station last night and parked nose into the charger and when I pull the hose and plug in the nozzle it needs to go around the charge port door (hence rubbing on it). This charger cord had a suspension devise to help lift up the cord (similar to some gas pumps) that felt like it had a tension pull back to the charger which caused the nozzle to bend back to the charger also and not have a solid connection. May have been the design of this charger...first time at EvGo for me....only been to EA charger once or twice without this issue.
Maybe I'm just too used to using Electrify America. There's no way that cord is hitting the charging door when plugged in. The end of the handle sticks out as far as the door, and that thick cable won't come close to bending that tightly.
I could maybe see some thinner L2 cables grazing it though. I've had to stretch one across the hood a few times when someone was blocking the spot. Can't remember if the door got in the way. I don't think so but maybe.
Here's an EA handle plugged in...
Ford Mustang Mach-E Charge Port Door Backwards 973797
EasyPass
2021 MME Premium 4X, 2017 Fusion Energi PHEV
I also drive a 2017 Ford Fusion Energi PHEV. The charge door is in the same location as the MME, but the door swings up parallel to the fender instead of out. This makes the most sense to me for a variety of reasons.
I nearly ripped the MME Charge Door off on my garage center support post once when I thought it latched, got in the car in a hurry, failed to see the warning on the small screen, and backed out just enough to pop the outer door shell off the arm before I stopped in time. I ended up with a very small dent in the fender where the charge door pressed in, but the outer plastic door cover popped right back on. It could have easily been a lot worse in a matter of miliseconds. So I don't get this design decision in any rational way.
:mad:
ReelSweet
ReelSweet
Jody
Connecticut
Mustang Mach E
that's definitely not like the EVGo charger I was at last night. The nose of the vehicle was right in front of the charger and the hose from the size would need to come under the charger port door.
ARK
Los Angeles
'21 Premium SR AWD
I like backing in too because it often looks better to park that way, but it’s really not easier. At best, if you live on a pretty slow street, it’s not much harder, but if you are dealing with traffic and obstacles creating visibility issues, no way.
dbsb3233
TimCO
Colorado, USA
Many EA chargers are located in the front of the parking spot too (some are front, some are side), but even the ones in front don't come close to having the cable hit the door as the cable won't bend nearly that tightly.
I'll have to check some EVgo pics online to see how different they are. Don't think I've ever seen one. They have almost no presence in the mountain western states I'm usually road tripping through.
ChuckA
Chuck
North Branford, CT
Accountant-Retired
The difference is that in a non-EV you pull up along side the fuel pump.
The EA chargers in North Haven CT and Waterford CT have canopies where you pull along side like a gas pump. The pull-in style isn’t universal.
revised: no canopies but the charger is on the side in the mid car length. It’s still pull-in or back-in.
ReelSweet
ReelSweet
Jody
Connecticut
Mustang Mach E
Awesome....I used the EA chargers in Manchester CT and Trumbull CT and they were pull in nose first. Will have to check out the Waterford one when I'm down there....sure should be simple with side pull in...thanks for the info.
dbsb3233
TimCO
Colorado, USA
I actually prefer when EA places them along the front in a row instead of on the side of the parking space as they often do. When along the side, they usually don't widen the parking spots, so it can be really tough getting the car doors open without banging them on the bollards...
Ford Mustang Mach-E Charge Port Door Backwards 988656
The holy grail of charging station formats is the gas station model (pull-thru islands), but they're rare. The best one is still probably the one in Baker CA...
Ford Mustang Mach-E Charge Port Door Backwards 1057674
Scc18603
Steven
PA
Ordered 22 Mach e rwd, red. 17 CTS, 22 Jeep GC
Technology director
It would be nice to have one on each side.
I had a charging location with two chargers. Backing in made it to far for the front driver side, and pulling in made it to far over the car.
Waited for the no ev spot to park and hookup, and that was a stretch.
Guess I should pickup a j1772 extension cable.
dbsb3233
TimCO
Colorado, USA
Wait until Tesla finally opens up Supercharger access to CCS use, then you'll really wish there was a port on both sides. Their cords are really short, and they're on the wrong side (for us, the right side for their cars). Tesla drivers will get mad at many CCS drivers because many will have to use the adjoining parking spot to get the cable to reach, which will block them from using the adjoining charger.
It's gonna be a mess, unless Tesla decides to offer much longer cables. Which is sounding doubtful (at least initially).
I have said this before… The door should open like my Fusion Energi’s charge port door: Pop out and swing up. Ford already had the mechanism designed and just needed to beef it up a tiny bit for the bigger door. ??
