Lift Loop For Cargo Floor When Under Rubber Mat
NY_Cade69
Cade
I didn't like having to lift the rubber mat to then grab the handle to lit the floor.
So I found a Mach-Easy solution. I took the handle off the floor - 4 Phillips head screws from the underneath.
The handle clam-shells at the rear edge.
I happened to have one of those slip on dog leashes from my vet, and it fit right through the slit in the handle. I didn't need to cut the rubber floor,
After checking for fit/length, I just screwed the handle back together.
NOTE, you dont want the loop long enough to interfere with the liftgate latch.
Right now I just have it friction fitted and left the entire length laying on the floor, it ain't going nowhere, and I have an easy way to lift the floor.
Those gripper spikes are a bit sharp...
Ford Mustang Mach-E Lift Loop For Cargo Floor When Under Rubber Mat 1777044601175-06
Ford Mustang Mach-E Lift Loop For Cargo Floor When Under Rubber Mat 1777044655843-gv
Ford Mustang Mach-E Lift Loop For Cargo Floor When Under Rubber Mat 1777044727238-8v
Dontforget91
Nathan
Bloomington Il
2023 Ford Mach-e Mustang
First post to say this has been my only half real complaint since buying the mache two weeks ago. I will also be steeling this.
I take it you have the floor set in the upper position and use the extra space for storage? Otherwise for me (floor in the lowest position for 5 years now), it seems like a solution looking for a problem.
NY_Cade69
NY_Cade69
Cade
Yes, my floor is on the upper position, I like being able to us the under floor area for various small things without cluttering up the main area, so for me it was a problem that I solved... :D
kjlebleu
Kathy
Morgan Hill, CA
2025 Mustang Mach E
Accounting
I don’t yet have the OEM mat for the back area, but I do want to get one and will likely steal this as well when I do!
NY_Cade69
NY_Cade69
Cade
It wasn't really obvious to me as to how to lower the floor just by looking at it, but I gave it a shot.
I still like the usefulness of my pull strap... :D
Also, since I had it from my last 3 suvs (Escape, Explorer, and Cherokee), I set in a black harbor freight moving blanket, it's a perfect fit folded in half...
Edit, measured the blanket, it's 40"×72"...
Ford Mustang Mach-E Lift Loop For Cargo Floor When Under Rubber Mat 1777236260395-tk
Also, since I had it from my last 3 suvs (Escape, Explorer, and Cherokee), I set in a black harbor freight moving blanket, it's a perfect fit floded in half...
Back in the day (Insert Pepperidge Farms Remembers meme here), when we were making reservations for this car that most of us hadn't even seen on a live feed, I neglected to order the interior protection kit (the weatherized floor mats was all back then). So I bought the mat set from a Ford Dealer online and had it shipped here. When the car finally completed its 16-week journey to Nowhere, Hawaii, I immeditaely tried to put the trunk area floor mat in, but it didn't fit. Obviously a Ford mix-up. Yeah, no. Putting the floor in the lower position solved the "Ford" misdesigned the matts issue ;). But it wasn't intuitively obvious. To me, anyway. No, I had not yet RTFM. IMO, the handle is still a good idea in either position, though.
