- Jim
- Sep 10, 2020
- Wayne, PA
- 2021 Infinite Blue Premium Mustang Mach E ER AWD
- Retied (formerly tried to herd highly technical, independent cats)
Admins, please move if appropriate but I did see other discussions of RATGDO in this sub.
I’m looking for anyone who might be able to help me diagnose problems with RATGDO or point me in the right place. I posted the below to the RATGDO sub on Reddit a few days ago, and did not get a response.
I have a Chamberlain 41AB050-2M (Security 1.0+, Purple Learn Button, Manufactured July 2009). I replaced the original wall control panel with the 889LM panel, as recommended. After putting in the new panel (and before installing the RATGO DISCO), everything was working fine. The outside keypad opened and closed the garage door, the 889LM panel opened and closed the garage door, and the motion sensor turned on the opener lights whenever there was motion (such as walking into the garage from the house).
I received my RATGO DISCO with parking assistance laser module. I use Apple HomeKit, and was able to configure it with Firmware 3.0.7 using Chrome on my MacBook Air M2 without any issues. I used the pass-through ports and the 3-wire (Red/White/Black) pigtail to connect it to the garage door opener.
There are two sets of wires (4 total) coming from my obstacle sensors up to the GDO. For each obstacle sensor, there is a white wire and a white wire with a black stripe. When connected to the GDO, a white wire and a black wire were twisted together and inserted into the white port on the GDO. The other white wire and black wire were also twisted together, then inserted into the black port on the GDO. The wiring diagram for the RATGDO DISCO shows two white wires from the obstacle detectors going to the second terminal labeled "W" on the bank of 4 pass-through terminals, and the two black wire going to the terminal labled "B" on the bank of 4 pass-through terminals, so I went ahead and wired the obstacle sensors that way.
Here's what works:
I'm able to access the status webpage from Chrome on my MacBook by going to the IP address assigned to the RATGDO DISCO.
I'm able to open the garage door from the status webpage by clicking the "Open Door" button. it usually takes clicking 2-3 times on that button before it responds.
I can both open and close the garage door using the 889LM control panel.
I can turn on and off the GDO light using the 889LM control panel.
I can turn on and off the GDO light using the control in HomeKit.
I can turn on and off the parking assistance laser using the control in HomeKit.
I can open the garage door using the control in HomeKit.
I can open and close the garage door using the remotes.
Here's what doesn't work:
The motion detector on the 889LM no longer turns on the lights. (Note: I DO have the wall panel motion trigger checked in the settings webpage.)
I am NOT able to close the garage door from the status webpage by clicking on the "Close Door" button. All that happens is, each time the "Close Door" button is pressed, the beeper on the RATGDO DISCO beeps several times, and the GDO light flashes, as if there is an obstacle blocking the sensors (there is no obstacle).
I am NOT able to close the garage door using the control in HomeKit. Again, all that happens is that each time I slide the garage door control down (to the "closed" position, the beeper on the RATGDO DISCO beeps several times, and the GDO light flashes, as if there is an obstacle blocking the sensors (there is no obstacle).
To summarize: I can only CLOSE the garage door using the wall panel or a hand-held remote. I can't close it from HomeKit or the web interface. The motion sensor on the 889LM panel no longer turns on the garage lights.
I've rebooted the device a few times, and no change in behavior.
Any ideas?
Here's what works:
Any ideas?
