- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
13.43 volts means the car is on or charging the 12V battery. If you want to check the resting voltage properly, you need to open the hood, then come back in 30 minutes to read the voltage on the battery. If you open or close any doors or have your fob or phone in your pocket near the car during that time, you will wake up the car and the reading won't be accurate.I am new to this Forum. I have a 2021 Premium extended battery Mach-E with only 2600 miles on it. I keep getting the following notification "Please plug in Mach-E to recharge its battery. Its voltage is low, which could make it difficult to start your vehicle". This notification only happens when my vehicle is unused and unplugged for about 5 days. When I last got this notification the HVB was at 99% and the LVB was at 13.43 volts. Do they monitor the 12-volt battery by the length of time it is off the battery charger? Thanks for your help.
That is correct, 3rd party apps or home automation can cause 12V battery drains. Aftermarket things wired into the car can also cause them, or simply welcome lighting from too many activations (not all cars ignore subsequent activations).The same thing has been happening to my car too. I took it to the dealership and they said there was no codes showing when they ran the diagnostics. They kept my car for almost 2 weeks trying to figure out what was wrong with it. They also said someone at Ford told them to make sure we didn't sign into other apps using the my ford account login cause that would interfere with the car system. They told me to take the car back if i continued to get the 12V faults, which I still do but the car runs fine.
If you get the 12V drain message more than once a week, you should address it.
See this topic for more ideas about 12V drain causes: https://www.macheforum.com/site/threads/how-to-recondition-service-your-12v-battery.11069/
