Lucid Gravity Debut
joes723
Joey
Black Diamond
'22 GTPE IBSM "LITHEUM"
A frunk designed to be sat in!
2025 Lucid Gravity Is Queen Of The Electric SUVs With A 440-Mile Range (jalopnik.com)
The Gravity has a frunk you can sit in and a starting price of under $80,000.
By
Daniel Golson
Published18 minutes ago
Comments (1)
Ford Mustang Mach-E Lucid Gravity Debut 1ba1c212a7896fc2be7411c6229e0ca0
Image: Lucid
Californian startup Lucid took a bold approach for its introduction to the world, launching in 2021 with the phenomenal Air, a large electric luxury sedan that entered a small, competitive segment of the auto market. Despite garnering tons of acclaim—including from me—the Air has been a slow seller and the brand has been losing a ton of money. Enter the new Lucid Gravity, a three-row SUV with super promising specs that will hopefully turn the company’s fortunes around.
Surprisingly, the Gravity rides on a totally new platform that was developed specifically for SUVs instead of just sharing the Air’s architecture. It also uses next-gen versions of Lucid’s motors, which are the most power dense production units in the world, and an updated 900-volt electrical architecture. In its top trim Lucid says the Gravity will hit 60 mph in under 3.5 seconds, have a payload capacity of more than 1,500 pounds and be able to tow at least 6,000 pounds. There’s an optional adaptive air suspension package that Lucid calls Zero Gravity, which will have manual height adjustments to assist with off-roading.
Ford Mustang Mach-E Lucid Gravity Debut 453ef834573d18bf715baf676a781e9c
Image: Lucid
Lucid says the Gravity has a new battery pack that’s smaller, lighter and uses fewer precious materials, though no specs have been given. Using a 350-kW fast charger the Gravity will be able to gain 200 miles of range in just 15 minutes, and it should take less energy to charge than current Lucids.
As we’ve come to expect from Lucid, the standout figure is the Gravity’s range. Lucid is targeting a maximum range of over 440 miles for the Gravity’s top trim, which not only is far beyond any other electric SUV, but is greater than every other EV period save for the Lucid Air. That figure is even more impressive when compared to the longest range versions of other three-row SUVs—the Kia EV9 (304 miles), Mercedes-Benz EQS SUV (305 miles), Rivian R1S (352 miles) and Tesla Model X (348 miles)—and those ranges are mostly reserved for the lower-powered trims.
Helping achieve that massive range is a drag coefficient of just 0.24, which matches the Model X and bests every other three-row SUV (and most SUVs period). Unlike the Model X, though, the Gravity didn’t have to resort to a slippery coupe-like profile to achieve that figure, instead going for a traditional two-box silhouette. While Lucid hasn’t given any dimensions yet the Gravity looks very long, with a stubby nose and short front overhang, a gently sloping low roofline that ends in a dramatic rear spoiler, and a generous rear overhang. Broad shoulders, big wheels that tapering roof give the Gravity a really hot stance, especially when viewed from the rear.
Ford Mustang Mach-E Lucid Gravity Debut a5ec787a2741fbfa12a5f1234b6d97f2
Image: Lucid
The design of the Gravity has evolved quite a bit from the initial concept that was teased in 2020, but it sticks closely to the design language established by the Air sedan. It’s got an aluminum blade up front that acts like a furrowed brow for the LED headlights just like on the Air, and the taillights are almost identical to the Air’s as well. The Gravity’s roof is finished in a contrasting aluminum finish, with some interesting trim at the floating D-pillar. The Gravity’s doors are frameless, and the side glass looks super flush.
Space is paramount to any three-row SUV, and the Gravity has it in spades. The second and third rows both fold flat to provide more than 112 cubic feet of cargo space, 30 cubic feet more than the EV9 and only 10 cubic feet shy of a Chevy Tahoe. The Gravity also has a huge frunk, with a large front opening and hinges that hold the hood at a near-90-degree angle so that people can sit and lounge in the frunk.
Ford Mustang Mach-E Lucid Gravity Debut 980616f48229d34899e70e90220098b0
Image: Lucid
The second-row bench slides fore and aft for more legroom, and passengers in the middle seats can use tray tables that deploy from the front seatbacks. The Gravity’s panoramic sunroof stretches all the way back to the third row, and the windshield flows seamlessly into a pano roof panel as in the Air. (It doesn’t seem like the Air’s annoying sun visors have been redesigned, though.) All of Lucid’s images of the Gravity show a three-seat bench for the second row, but I wouldn’t be surprised if a pair of captain’s chairs are optional.
One of the biggest gripes with the Air has been Lucid’s infotainment system. While stunning to look at, it had lots of teething issues ranging from software bugs and missing features to just plain bad user functionality. Over-the-air updates have fixed a lot of the problems, but it’s still not perfect. The Gravity introduces Lucid’s next-generation user interface and control setup, and it looks to be much improved.
Ford Mustang Mach-E Lucid Gravity Debut ab39502bc623fc4aed45dd7f43773b9d
Image: Lucid
A curved 34-inch display sits atop the dashboard, and it appears as one seamless screen instead of three units put together like in the Air. The left half of the screen sits in front of the driver and acts as the gauge cluster, while the right half is touch-operated and is used for navigation, media or Apple CarPlay. Left of the gauges are touch controls for commonly used functions like the lights, defroster and tailgate, and the Gravity has a physical stalk for the wipers and turn signals. The steering wheel is a new squircle shape, and it has new touchpads to control the infotainment and cruise control that look much nicer than the Air’s annoying switches.
One of the Air’s coolest features is the Pilot Panel, a separate vertically oriented touchscreen in the center console that can be hidden away in the dash at the touch of a button. Sadly the Gravity’s Pilot Panel doesn’t seem to hide away, but it’s much larger and shaped like a tablet, and the menus have been redesigned to be much easier to use at a glance. There’s a new control bar at the bottom of the screen to easily access different settings, and the base of the screen has physical switches for the climate controls and volume.
Ford Mustang Mach-E Lucid Gravity Debut c896d56dd4ae6c1bf67a5d31415b9388
Image: Lucid
Beyond the technology, the Gravity’s interior has a lot of cool design touches. There’s real wood and aluminum trim, and Lucid mixes fancy leather with sustainable materials like alpaca wool. Sadly, it doesn’t seem like the Gravity will have split color schemes for the interior like the Air, but lots of color is used throughout and the seats have cool stitching and perforation patterns. The center console has a glass cover that slides open to reveal the cupholders and storage cubbies, and Lucid’s cute bear logo is used in a few places.
Production of the Gravity will begin in late 2024 at the same Arizona factory that currently builds the Air. Lucid says the Gravity will start at under $80,000 for the base model, aligning it with the Air, though the top-end Dream Edition will likely come in around $150,000. We’ve got our boots on the ground at the LA auto show where the Gravity is making its public debut, so we’ll hopefully learn more details soon. Fingers crossed there will be a high-performance Sapphire model, too.
Deleted member 16048
Guest
Looks phenomenal and has all the specs! I'm sure it will cost a pretty penny though.
I agree, it seems designers are getting more in tune with features that customers are looking for. The frunk design is actually really great. I always thought the Lightning had the best frunk since you can easily get things into it. Having the grill attached like that I think is the best design.
MellowJohnny
Christian
YYZ
Solution Architect
Let's hope this is the car that saves Lucid. The Cayenne basically saved Porsche, so crossing fingers.
voxel
Nelson
Altamonte Springs, FL
22 Mach-E 4X, 23 GC Limited
Looks like a Lyriq or Taycan Turismo.
Fremont Kid
Colorado Springs, CO
Retired IT
I'm waiting for software assurances, which has been Lucid's weakness.
buzznwood
california
focus st & GTPE
Hopefully they make enough to keep lucid around long enough so they get to do 2 row mach-e / model Y sized equivalent. Overall I like it but I just can't get past the allegro square steering wheel :( is was stupid back then and it is just as stupid now. I have no clue why everyone is giving them a free pass now.
The bigger thing to me is the low cd figure while also maintaining a traditional SUV shape, this may well impact Fords 3 row suv that ditched the original boxy design and started again down the aero route and as a result has very polarizing looks that have not gone down well if rumor mill is to be believed.
If the lucid in the real world can match the projected range then for a lot of people than want and need a 3 row SUV it will prove that it is possible to maintain the practical boxy shape they want without negatively impacting range.
MachEasy
Randy
CA
2021 Mach E, Jeep
Business Owner
Looks like a glorified Toyota Venza but I don't hate it. There are very few 3 row EVs and nothing with a range that big. It's very different from the Rivian....much more an around town cruiser. It definitely has an elegance to it....just don't know if it's something I would buy.
This is totally at the top of the list to replace my MME. But it is a year before real world testing is revealed, and I am really interested in 80 mph highway range. Some independent reviewer or owner will need to test it to see how far it can really go on the highway.
Pushrods&Capacitors
Round Rock, TX
Analyst
The Gravity is what Lucid needs right now. They’ve already been cutting losses per car from $500K to near $100K and new production efficiencies are cutting it further. That said, the Air is a sedan and those just don’t sell in huge numbers any longer. They have $6.8B cash on hand and the Saudi Sovereign Wealth fund as backing so I’m thinking they’re gonna make it. Sure hope so.
Pushrods&Capacitors
Round Rock, TX
Analyst
Just look at all the Air range tests and deduct a bit for the extra frontal area/weight. It’ll do just fine range wise. Likely go further than your bladder. ?
