LVB and long-term storage
valeriol
Valerio
Jersey City
2021 Mustang Mach-E Premium RW
This is just a theoretical question, no immediate need.
If you need to leave the car still for 5 or 6 weeks you will probably end up with a dead LVB. If you disconnect the LVB, can you then open the car with the emergency leads in the bumper or does the LVB need to be connected to work ? Don't know how the circuit is designed.
Have you read the other posts on storage, or the manual?
Charge to 50%. Unplug from charger. Disconnect 12v or put on a trickle charger.
The leads only work when there is no voltage, which is what exists when it is disconnected, so yes, they work fine.
William
William
Rochester, NY
2014 Ford Edge, 2021 Mach-E Premium
As I explained on another thread, I have left my MME in my garage for 5-6 seeks in Feb-Mar at ~50% SoC for the past three years whilst I visited CT (from Rochester, NY) in my ICE. Every time I have returned I find my MME just the way I left it. Started up just fine. I just checked my LVB and Ford.com says it's at 100%.
valeriol
valeriol
Valerio
Jersey City
Yes I did read many posts and the manual and I know about charging to 50%, but I did not notice an answer to the question about disconnecting the leads, I guess I missed the point.
Thanks for the answer.
valeriol
valeriol
Valerio
Jersey City
Hi William,
I had seen your post, I just thought that disconnecting the leads might add an extra layer of protection, but wasn't sure if that would then make access impossible.
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
I go out of town every summer for 4-5 weeks. I leave it at whatever charge level is at. I came back and the car was fine.
Adventureboy
Ontario
Your LVB will not die. The MME will charge it from the HVB when needed. For 5-6 weeks the only thing you will notice is Fordpass likely won't work after a week or so since the car shuts down non-essential modules including the connection modem.
If you want to save wear and tear on your LVB, put a trickle charger on it - This will stop it from charge cycling.
If you want to minimize HVB battery aging, leave it between 30-50% SOC.
Otherwise, park it and leave it and it will pick up where you left off give or take a percentage or two.
