Mach E stuck in Kansas?
ABjolly
Aaron
United States
MACH E Select
My delivery date was 3/17-3/26 but it didn’t show up. The visibility report says the last status update was 3/17. The dealer thought I was strange for thinking it’s not a good sign that there hasn’t been a status update since the 17th and the car did not show between the delivery window. Also last thing palsapp says is that it arrived in Kansas on the 17th. So is it most likely still in Kansas or what my dealer suggest it’s on a truck on the way here?
agdad
Derek
78155Ray
2020 Ford Edge
Mine sat at the rail yard in KC for a month before getting shipped to Bryan Texas
Once shipped, it was at my dealership in 3 days
the day after I picked it up, it was still showing it was at the rail yard !
ABjolly
Aaron
United States
MACH E Select
So it never showed that it shipped past the rail yard? I guess that’s a little hopeful!
AKgrampy
Fairbanks, Alaska
Palsapp only shows trucking data. My report only shows that my Mack was moved from one rail yard to another. The VVR then identifies which railcar it is on. Unfortunately not one of the rail systems which can be tracked. If you are close to KC you may then see more info on Palsapp if trucked. Otherwise the VVR should identity the railcar it is loaded onto and you may be able to track its progress.
agdad
Derek
78155Ray
2020 Ford Edge
Oh yea it showed shipped ...... about 5 days after I took delivery !
Dancefreak
Hermosa Beach, CA, USA
2022 Star White Premium extended battery eAWD
KC is definitely a choke point in transit. Mine sat for more than two weeks on arrival from Mexico. Then was trucked and delivered to the departure rail ramp and has been sitting there for another week so far.
