MachE GT/GTPE Performance Limiters Explained
dethbunny
Christian
2021 Grabber Blue GTPE, 2023 Dark Matter Gray P4X
Build Imagineer
And the screwball limiter I woke up to the other morning (13 lucky bars here!):
Yeah, I think that's the exact same set of bars I had seen - Didn't try to power cycle the car before I gave it a charge up above 80%, so there's no real science to my statement. But I have no other explanation for why I saw 13 bars that day.
Wes1776
Wes
Dekalb
Clarity, M4, Yj
What is the acceleration rate change reduction for each of the limits above 72mph?
Mach1E
Not even sure how to answer this.
Do you mean; how much power do you lose for each grey bar?
I don’t think that’s ever been tested (no Dyno tests), and as long as those grey bars exist, we can’t test what the power would have been without them.
Since they’re always there above 72 mph, how do you know what acceleration would be like without them?
My guess is the power meter (and grey bars) is somewhat based on percentages. But it doesn’t seem to be linear. When people have half grey bars, you lose much more than half your horsepower.
Kevin P
Burlington, KY, US
'21 MMEGT - sold, '23 BMW i4 M50, various others
My 2021 GT used to get poodlebars at EVERY start event when the car was switched off for more than ~ 2 minutes. I could run into a convenience store (usually for beer LOL) and come out, and it would have ~8 bars, regardless of ambient temp. They would typically last for a good 5 minutes of driving. It got to the point that I used ForScan to code the car to not beep the horn on walk-away left-on status, and I would just leave the car in the "on" position. It was the same way on cold-start in the garage, again regardless of ambient temp. EVERY SINGLE TIME without fail.
One of the contributing factors to selling the car after 9 months/8k miles of ownership.
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
Thought I would try to collect some data for this thread yesterday. I drive a very long, straight back road that is abandoned at 5AM.
It was 21 degrees F when I left for work. Car charged to 90% to make sure that wasn’t a contributing factor. No preconditioning or remote starting.
When I started the car, I immediately had 2 bars. It should be noted that toward the end of last winter, after some Update, I noticed this as a change. I felt like I was getting fewer bars due to temperature but couldn’t go back and prove it. Nobody else was talking about it and I didn’t want to start any arguments. But last year, at the beginning of winter, temps below freezing was worth 7 bars. Now it’s 2.
Anyway, I set my phone to record the IPC as I drove and the results were:
2 bars unless I accelerated hard, or got above 80 MPH.
At 81 MPH it jumped to 4 bars
At 86 MPH it jumped to 6 bars.
At 90 MPH it jumped to 8 bars.
At 95 MPH up to 9 bars.
At 97 MPH up to 10 bars.
At 102 MPH up to 11 bars.
At 105 MPH up to 12 bars.
Coming off the accelerator one the way back down it dropped to 11 at 99 MPH
But not back to 10 until 84 MPH
A sudden drop to 6 bars at 75 MPH
and down to 3 at 73 MPH
and 2 bars at 71 MPH
Never below 2 bars (I believe due to the temperature.)
This morning is was 40 degrees F and I still had 2 bars. So I am not sure at what temperature the 2 bar penalty for low temps kicks in. Though the charge was down to 83%. But I still don’t think that is low enough to matter.
Tang
Canada
Mache GTPE
I 100% agree that temperature bars are showing way less this winter. Last winter at 0C I’ll get quite a few bars. This year only 2 show up. At -12C I had 4 bars this winter, last winter the car will feel significantly slower.
GTPE22
SoriceConsulting
Sal
NJ, USA
sorice.com
2023 GTPE, Rapid Red
IT Consultant
Searched but could not find the answer to this question - what does the vertical gray bar represent (circled in yellow)?
Ford Mustang Mach-E MachE GT/GTPE Performance Limiters Explained 1711228318525-m4
Mach1E
Coasting.
To the right will go blue when you hit the accelerator pedal, to the left goes green for regeneration when slowing down.
Clockwork
2024 Mustang Mach-E Rally
Any revisions to this for 2024 models? Have we seen any changes outside of the 5 second limiter?
Mach1E
Unclear so far. We know with the performance upgrade and 700 tq, it has a longer limit, but there is still a limit.
Haven’t seen an in depth testing nor a test of a GT without the performance upgrade to see if it is any different.
First 2024 drag racing video we have, the idiots driving put it in unbridle extend mode and killed the power so that doesn’t help us determine anything except that 2024 unbridle extend is faster than 2021-2023 (ran a 12.9 1/4 vs 13.4 for prior years).
load97
No3ne
A guy on fb group posted his Draggy results using his 23’ GTPE VS his 24’ GTPE. Huge improvement. He mentioned up top the car had decent amount of power. Good for passing cars etc if needed.
garyd9
Gary
Pittsburgh, PA (USA)
2023 Mach-E GT
All the Mach-E GT's are good for passing other cars. It doesn't need to be a particular MY or have the performance addition.
I saw the forward of the FB Dragy run in another post on this forum. The ā€˜24 runs a 114mph trap speed vs. the ā€˜23 running 104. So it seems that it takes longer for the 2024 to pull power (IOW, to go off of Boost mode). ??
load97
No3ne
Maybe at your level, not at my level of the performance I’ve come to expect from a Mustang. (Especially at lower SOC with jail bars).
