Multiple error messages, one-pedal ABS braking, collision avoidance etc.
avdepaul
Drew
Chicago
Mach-e
Last night, after attending a concert, I returned to my vehicle, turned it on, and received a bunch of error messages. One pedal drive fault, abs module fault, powetrain malfunction, etc. The breaks were barely working and I slowly drove it to a nearby dealer, plugged in , and left a note that I would return in the morning. This morning I show up early, turn on the vehicle and it works normally. No repeat of any errors. Any ideas as to what happened. Is this an unexplained one-off.
If you have a 2021, I'd suspect a bad 12v battery.
Vgkfan
Keith
Nevada
2022 mme premium ER AWD 2016 Kia, 2003 Honda
I had a similar situation a year or so ago, don’t remember the exact details but made it home with reduced power. The next day the message was gone and car drove normally. Hasnt happened since. There is a recent thread on this so maybe a background update is throwing a wrench in the works.https://www.macheforum.com/site/threads/powertrain-malfunction-now-the-wrench-light-is-gone.44618/
Bobcat17
Gibsonia PA
2021 Mach E
I had same issue with my 2021 MachE.
Ford service did diagnosis test and my cameras were not functioning: thus many of the systems were not working and I received 3 or 4 messages on the dash similar to yours. The front and rear cameras had to be replaced as well as all wiring in doors. Big job. Ford had car for 9 days. Thankfully I have extended warranty so $5,500 bill only cost me $100. I hope you are still under warranty. Good luck.
  • Like
Reactions: TWD
