Bad Dolphin
Did you get the pro or clsssic Emporia? Do you have solar?Ashamed to admit, but I didn't know enough about chargers to even ask--that's just what they sent me! The Emporía software is very good, as you note. I like being able to track exactly how much we spend on in-home charging, but I'm sure there are many other features I have yet to discover.
The Pro comes with a second, very small, device which can be mounted in your main service box, in essence between the meter and your service. It can detect which way current is flowing. If you choose the setting in the app to activate it, it will only charge your (plugged in) Mach E if the house is sending at least an excess 1.5kg back to the grid. So it allows you to leave your car plugged in and automatically only charge on excess solar (this part may be available to purchase separately to use with classic.) I understand that the Pro also comes with software to share power between two chargers simultaneously from a service box only adequate for one at full charge rate. For example, you can have two Emporia chargers on the same service and two different EV's plugged in at the same time, and the software will reduce both from 48 to 24amps automatically to safely charge both vehicles simultaneously.
Do you use either of these functions?
