No simple Climate on Button via ford pass app (EU)
irishwill2008
Will
Ireland
2021 Ford Mustang Mach E RWD 75KW
Is there anyway to easily turn on AC / Heat via the ford pass app? I ask because I do not see any option? I only have departure time setup but if I want to heat the car up last minute before I head out, it is not user friendly having to go into departure setting and turn it on to start like 5 mins before going etc.
Other manufacturers have the ability to turn it on and off by a button on the app.
I have a Mach E RWD SR and based on Ireland.
Thanks!
irishwill2008
Will
Ireland
My app has a remote start button. Is that how you control the climate controls? You start it first and then the option appears?
Thanks!
JryErok
Poland
MME SR RWD Lucid Red
It is just this one button, no further configuration in Ford Pass unfortunately. You cannot set it to specific temperature. In SYNC settings you can only decide whether you want the remote start to use predefined settings for climate control or the settings from when the car was last used.
Also keep in mind, that remote start will run only for a set time, either 5, 10 or 15 minutes, though you can extend it in the app to 30 minutes.
irishwill2008
Will
Ireland
What does auto do? If temp is hot, will it enable the cool air and vice versa if cold, hot air is on?
Thanks for the help!
